Problem authoring a CVD using VCDEasy.
I'm trying to author a NTSC CVD. It's 358x480, 2680kbs VBR, 48.0 khz audio. I mux using TMPGEnc Plus 2.5.
If I mux as "MPEG-2 Super Video CD (VBR)", I get a message saying something about "packet overflow" and that it may not work. If I mux it as "MPEG-2 Video Stream (VBR)" it seems to mux OK.
I then try to author with VCDEasy 2.0 as "SVCD 1.0", but it autopads like crazy taking my 774mb file to 837 and does not fit on a CD.
I can author it OK as "VCD 2.0", if I mux it as "MPEG-1 Video CD (Non-Standard)". But for some reason my standalone reads it as a VCD 1.1 (that's what the OSD shows when it's loaded). Since it sees a VCD 1.1, I lose my sequencing, thus losing my menu that I created.
Is there anyway that I can get this CVD authored as SVCD 1.0, or am I going to be forced to go SVCD compliant so that I can use the menu? If that's the case I guess I'll just author as a CVD (VCD 1.1 or 2.0) with MPEG-1 Header, because I want to preserve for transfer to DVD±R in the future.
FWIW, my standalone is a GE 1101PA. This player is flashable with the APEX AP-703 region/macrovision free firmware. Using either firmware reads a VCD 2.0 authored disc as VCD 1.1.
Thanks in advance.
Ely
Try muxing with some other application than TMPGEnc (even if I can't see why TMPGEnc wont work).
Muxing as MPEG 2 Video makes VCDEasy pad the mpg, and it will probably not work at all as CVD (besides getting too big).
/Mats -
Originally Posted by mats.hogberg
So even if I was able to mux it as "MPEG-2 Super Video CD" without error message or in another app (like which?), VCDEasy will pad it anyway? I guess that with a full capacity sized file it's not worth it, then.
I should just stick with the VCD 2.0 played as VCD 1.1 in my standalone and lose the menu. The menu works fine in PowerDVD when authored as a VCD in VCDEasy, so it is a problem with my player.
FWIW, my standalone plays the MPEG-2 CVD (with "MPEG-1 Video CD (non-standard) header, authored as a VCD 2.0) at the specified bitrate without a hitch. And, it looks beautiful, especially considering it's a capture from programming that I recorded from my dish to a standalone PVR/DVR. -
When muxing as VCD with TMPGEnc, you're doing the "header trick" which mostly is used to fool players that refuse to play SVCD to play them anyway...
My suggestion is that you try something else besides TMPGEnc to mux your audio and video as SVCD.
/Mats -
Thanks, Mats. I'm going to try to mux with bbmeg. I was told on another forum by someone who had the "packet overflow" msg, that muxing in bbmeg solved the problem. I appreciate your help. 8)
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 15:28 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
problem with fairuse wizard creating project
By Wizard23 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 14:30 -
problem creating my own component cables.
By nick101181 in forum Newbie / General discussionsReplies: 10Last Post: 2nd Oct 2007, 13:13 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11
