  1. Hi,
    Got two mpg's and author a DVD in DVDMovieFactory 2.
    The two mpg's are VBR and are added as two separate titles.
    Then I made two mp3 files, with length equal to the two mpg's.
    Now, I want to replace the original sound with the mp3's. I select "replace audio" for each of the titles and select the mp3 files.
    In the preview section, everything seems perfect, audio is replaced in both titles, but after generating the VIDEO_TS directory and watching the DVD in WinDVD, only the first title had it's audio replaced.
    Anyone else who had this problem?
    I guess this is a bug ... or ... ???
    Thanx in advance!
    /Nisse
  2. Try the following...
    1. Click the SECOND button in the lower left corner of the interface;
    2. After the PROJECT SETTINGS pop-up menu appears, UN-check the DO NOT CONVERT COMPLIANT FILES check box;
    3. Click the CHANGE MPEG SETTINGS button;
    4. After the small pop-up appears, click CUSTOMIZE;
    5. After the VIDEO SAVE OPTIONS appear, click the GENERAL and COMPRESSION tabs and adjust the project settings to precisely match the properties of your source clips;
    6. Click the OK button to accept the project settings;
    7. Burn the disc with the .MP3 files designated as audio replacements.
    Jerry Jones
    http://www.jonesgroup.net
    Originally Posted by f96nini
    Hi,
    Thanx in advance!
    /Nisse
