    Oct 2003
    Brisbane, Australia
    is there a special way to do this....to play in a stand alone....or will burning as a data disk do the trick......????
    thanks in advance
    "We want the finest wines available to humanity, and we want them now!"
    canada
    Unless your dvd player specifies that it plays mp3`s on a dvdr then its no,if you do a search you can find out how to use wav files with bitmap graphics to make an audio dvd.
  3. If your DVD player does play DVD-MP3's, I have a couple of players that wont, and a couple that will, you simply burn as data. Just burn one and see if it works.
