  1. Well, I've done everything just perfect, all the menus i need, the subs, everything. I preview it in the simulator navigator of DVDMAESTRO and everything is ok, i can change the subs, i can turn them on and off everything... So i compile it to the hard-drive and after that i try to preview it with power dvd and NO SUBS, nothing... Why?? What am i doing wrong??? Thanks in advance!
    did you choose to play a dvd from the dvd with powerdvd? instead of just play the vob files?
    You can also try windvd or burn on dvd+-rw media and test.
  3. Sounds strange. Never had such a problem so far. Did you select Display Subtiltes from PowerDVD menu? Did you have any warnings after compiling the DVD in Maestro?As Baldrick mentions you should select the .IFO file when playing the DVD from the hard drive not directly the .VOB files. I noticed also that the last version of PowerDVD /supporting 24bit/96kHz playback/ has some issues playing DVDs from the hard drive.
    Enjoy!
  4. Very grateful to all of you but the problem was that when i press compile DVDMAESTRO says that before compiling it needs to save, and i had never saved before compiling, i had made a save before i imported the subtitles into my project so when i choose not to save before compiling it compiles the project saved before when no subs were imported. Sorry about my english i hope you understand. Now everything is ok, i just needed to save before compiling. Thanks everyone!
