Hello
I dont know if anybody can give me a straight answer about this...but i would be gratefull...
I am filming some wedding movies and i want to distribute them on dvd.. the thing is that i dont know for sure if those dvd's can play in all standalone players..
Is there any way that i can guarantee this to my costumers?
ok i make the post production in premiere and i burn the dvd in dvd architect...i use dvd -r...i try a couple of player but no success
my writer is Tec ang the standalone player i used was an aiwa,,,
no luck..
can anybody suggess some general rules of getting the most compability with standalone players?
sory for the long post
thnx in advance
First the media:
Next UDFs:DVD-R and DVD-RW
DVD-R/W was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 77% of all DVD Players and most DVD-ROMs.
DVD-R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R/W has some "better" features than DVD-R/W such as lossless linking and both CAV and CLV writing.
DVD+R is a non-rewritable format and it is compatible with about 87% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 77% of all DVD Players and most DVD-ROMs.
DVD+R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.
Use UDF 1.02. It is the oldest, and older and newer players can play it, while older players cannot handle the later UDFs (1.05 and 2.01).Hello. -
Use DVD Decrypter for ALL DVD burns.Originally Posted by kseni
If Premiere only creates the VIDEO_TS directory then you also need the AUDIO_TS directory (this makes the DVD fully compatible with the specifications). Finally create a .ISO file from your VIDEO_TS & AUDIO_TS directories using ImgTool Classic standalone. This file is what DVD Decrypter uses to burn from.
DVD Decrypter and ImgTool Classic are both FREE
Finally the media:
I would use -R media and I recommed Ritek 4x G04.
I have been creating DVD's for the last 18 months and this is the software and media that I use today.
Let us know how this works with your two customers that had problems playing on standalone machines.
PS
I put LABELS on ALL DVD's without ANY problems. I use the CD STOMPER machine and STOMPER labels. -
thnx a lot for your answers..I would try them and let you know..
I burn those dvd's with dvd architech by the way..
Maybe this is the problem?
thnx again
general conversion advice (blueray and dvd)
By ripit in forum Video ConversionReplies: 5Last Post: 16th Feb 2011, 07:24 -
few general questions about dvd converting
By kobi_af in forum Newbie / General discussionsReplies: 11Last Post: 25th Nov 2009, 17:19 -
General information on how DVD players and their firmware (or software)
By Samazama in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2009, 17:51 -
A general problem, I don't know what to call it.
By jonniemn in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2007, 15:54 -
General DVD player problem.
By Ba745 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 27th Jun 2007, 05:20
