Hi..
I'm looking for a protection system for VCDs, so that they can't be copied.......... I know this sounds weird, but I really need it.
I have no idea of how to make this posible, I mean, even software CDs of important companies can be copied.
If you have idea of where I can get an aplication, code, or whatever, for making this posible let me know.
Any other protection idea may be post. Thanks.
..I mean, even software CDs of important companies can be copied...
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
That's right. Do you honestly think, you can protect yours? -
best bet is to just not let people borrow them...theres a way around everything in this world...
i find that if i have chapters cut into my mpg, i cannot copy them to my hard drive, but i can still make copies of the cd
good luck with that
im sure its impossible
it is impossible to copy protect your vcds that only way u can mak it impossible to copy a any cd is to scratch it
Hummmmm..... I tougth this can't be done because of the structure of a VCD, we are talking about just some files..... I had the curiosity cause someone gave me a copied software CD that if it was copied to the HD and then burnned, the software won't work, normal... But....... when I tried to clon it with Nero and Cloncd, I got problems when the Cd is being read. The reading speed became very very very slow and I couldn't clone it??????
I have no idea why, or how this was made, maybe it's simple but I don't know...., so I'm interested to find how to do this with specific files for a VCD. -
Firstly, a VCD is NOT a CD-ROM.
Secondly, you can do all sorts of copy protection tricks on a CD-ROM that you CANNOT do on a VCD.
The physical layout of a VCD is as important as the content.
Herein lies the problem. Most copy protection schemes for data CDs involve messing around with the PHYSICAL LAYOUT of the disc. However, if you start doing that with a VCD, it won't be able to be read on a stand-alone player anymore.
I'm sure that there are some trivial tricks that you could employ for the VCD, but they would be just that, trivial. Anyone with any PC experience or knowledge would be able to overcome it.
Basically, as someone stated before, the best copy protection is to simply not lend it to anyone.
Regards.
Michael Tam
w: Morsels of Evidence
legacy software or broken code?!
By kentback in forum DVD RippingReplies: 4Last Post: 3rd Dec 2008, 22:37 -
Install only selected program from a bundled suite software
By ks47 in forum ComputerReplies: 6Last Post: 16th Apr 2008, 09:39 -
Need program/software for Vista
By Me-Hostage in forum Authoring (DVD)Replies: 2Last Post: 5th Sep 2007, 05:16 -
Install only one program from a video editing software
By ks47 in forum ComputerReplies: 2Last Post: 29th Aug 2007, 00:31 -
moduleC:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx failed to regis
By itsjimmyb in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 30th Jul 2007, 08:41
