I have a divx file that is 512 x 384 and would like to make it into a mpeg file so I can load it in TMPGEnc DVD Author. I use TMPGEnc to encode first but when I convert it, the quality is really sacrificed. I just use the normal wizard and so on, so that may be the problem? Could someone tell me the advanced way to keep high quality?![]()
There is no advanced way ...... there is no way....Divx to mpeg2 ....advanced way to keep high quality....
Garbage IN = garbage OUT
Buy the original. -
If the divx quality is good to begin with then encode at 352x480 at 3000kbps in 2pass encode.
I convert DIVX to huffyuv first then into MPEG2.
If the DIVX source is not at 720x480 etc., I add a black boarder around it to prevent the encoding software from scaling the image up.
You can add the border using avisynth or any video editing tool.
Yea, I know that converting into huffyuv takes up ALOT of space, but my encoding tool doesn't like frameserving.
Never had a problem with a bad encode or audio sync.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Thank you johns0 and awlchu for both your helpful comments.
To johns0:
Yes, the divx quality is pretty good from the start. I tried your method of 352x480 at 3000kbps in 2pass encode and then played it on TV, it looked a lot better than before! Less noticable pixels. But it was wide screen and the people in the video seemed a little squeezed. The other setting I used was 'Full Screen (Keep Aspect Ratio)'. Also, would changing the setting of 3000kbps greater make it even clearer?
To awlchu:
I will check out the tools you suggested also.
set the motion search to high [SLOW] 720x480 or 576 uk. full screen keep aspect ratio and tick the noise reduction box encoding will take a lot longer but quality will be better. what is the bitrate when you load the movie into tmpenc
2CD Quality Encoding.
By scott274 in forum Video ConversionReplies: 5Last Post: 17th Dec 2009, 18:05 -
Better for quality image: Dvdshrink or Divx encoding?
By perdomot in forum Video ConversionReplies: 1Last Post: 26th Jul 2009, 08:19 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 19:28 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Video_TS to Divx. super poor quality after encoding
By mistervolcom88 in forum MacReplies: 5Last Post: 13th Sep 2007, 13:49
