  1. Hello all. Ok the problem that I'm having is that I extracted a dvd to my hard drive with dvd decrypter now i'm trying to use DVD Shrink to shrink the DVD but I get an error that i'm missing VIDEO_TS.IFO file.
    I have the main movie files they are VTS_03_1 thru VTS_03_8 . and each is about 0.99 GB in size. I looked over the extracted dvd files and i don't have VIDEO_TS.IFO file and VTS_03_0.BUP. Now my question is is there any way and/or program out there where i can maybe convert the 0.99 GB files to .avi , MPEG or any other format. Or is there a way or program where i can try to get or repair the files I'm missing {VIDEO_TS.IFO file and VTS_03_0.BUP} . I appreciate any HELP that i can get and any ideas or tips. Thank You again.
    Sincerely Joneswoods1
    joneswoods1
  2. use ifoedit. I can create ifo files for you.
    here's the guide you want to follow.
    http://users.pandora.be/rudy.stremersch/createifo.html
  3. either use ifoedit that was mentioned or rerip the dvd. dvd shrink requires the the whole dvd.
    How Big A Boy Are Ya?
  4. I will try ifoedit. and will repost the results
    joneswoods1
  5. I'm having some trouble in the example in the link you provided for ifoedit they are using ifoedit v0.89 and i downloaded v0.95. when it asks me to change the hex number to a five i double click it but something else comes up diffent than the example. Please help . or where can i get v0.89.
    joneswoods1
  6. try downloading and installing the old freeware version of dvdfab.
    show dvdfab the folder where your vob files are and then use the create video manager button. It will create the ifo files for you.
