Anyone know of a good way to take a clip (DivX) and create a new file which is going in reverse/backwards?
You can do it in Adobe Premiere, in the timeline, right click on your video, and select duration. Whatever the duration is, add a "-" (minus symbol) in front of it. That should make it run backwards.
I was thinking about doing that with the movie "Memento" - since the whole movie is backwards I would like to see it the other way
but the action isn't reversed, just the order of scenes - just take it, cut it into component scenes, and reorder them from back to front.Originally Posted by PhreakPhish- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I found this tool over on the Pinnacle Studio 8 forum some time ago.
http://home.t-online.de/home/klaus.horst/hobby/
"Video utility to reverse an AVI, to mirror it and to generate Overlay/Split screen windows"
You will have to use the "Deutsch" (German) link on the website, but once the software is downloaded, it has an English option.
STR file format from SmartTV (need video expert for reverse engeneering?)
By dobi4eto in forum Video ConversionReplies: 20Last Post: 6th Sep 2021, 04:56 -
The reverse problem -- speeding up video (2x) to match audio
By hlygrail in forum Video ConversionReplies: 9Last Post: 2nd Dec 2009, 13:06 -
How to "reverse letterbox" 4:3 video?
By gonzoron in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 02:34 -
Making a Reverse Video Clip
By Squid_uk in forum EditingReplies: 7Last Post: 8th Mar 2008, 12:20 -
reverse play video (MCI command)
By mehdi0016 in forum ProgrammingReplies: 0Last Post: 31st Jan 2008, 12:03
