i hooked up my dazzle 80 and connected it to my camcorder and to my pc. i was wondering if anyone knows any good software that doesnt compress the video quality? i tried some program like window movie maker, and it was so junk. then some others which got better quality. my digicam is 1.04megapixil. so its pretty good i think
. when i hook it up to the tv, it was like dvd quality clear. but on the comp. its so junk..
help a sad little boy please...
trying to make a wedding movie for my aunty.
Does your camera output in DV format? If so you should use that format. If it's composite, then thre are quite a few options for capturing. Virtualdub for starts. You can capture in Huffy or PicVideo, then edit and encode with say, TMPGEnc. If you give a little more info, then someone here can probably give you some better advice. And we say always, look at the guides.
Convert from MiniDV to PC
By Tigerjon in forum Video ConversionReplies: 22Last Post: 12th Apr 2011, 22:44 -
MiniDV Recorder
By luckyo in forum Capturing and VCRReplies: 3Last Post: 9th Nov 2010, 07:07 -
Archive MiniDV
By bdr13278 in forum Video ConversionReplies: 7Last Post: 6th Feb 2010, 10:29 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 22:46
