Hey everyone
I am getting this invalid pointer error when it gets about 50% through a conversion.
Never used to do this before, and has only really started happening recently..
Anyone any suggestions on what to check for, or what could be causing it?
Any help or advice gratefully recieved.
Iceworx,
i know this is a different program but I also got the invalid pointer error yesterday using VCDEasy, this would lead me to believe that PERHAPS it's an OS problem, I uninstalled and reinstalled the program (not the OS) which seemed to correct the situation, Maybe you've already tried that ? -
I have tried to uninstall it, and re-install it, but i am getting the same error...
When i use 2 pass VBR is happens dead on 50% and if i use a CBR it happens within 2 minutes..
Could this be to do with the codec?
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 12th Jun 2010, 23:13 -
Invalid Pointer error #80004003 PowerDVD - solved
By montrealer in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2009, 08:49 -
VirtualDub invalid handle error
By 2manytapes in forum DVD RippingReplies: 0Last Post: 17th Mar 2008, 12:37 -
Getting error: Could not initialize encoder. Probably invalid input.
By chrishallowell in forum AudioReplies: 0Last Post: 1st Nov 2007, 23:29 -
vista DVD maker invalid pointer
By sue1951 in forum Authoring (DVD)Replies: 1Last Post: 19th Jul 2007, 10:04
