Hey folks,
I've captured and converted a recorded broadcast from my Tivoto burn it onto DVD. I've done this several times in the past capturing at 720X480 without any problems. However, I'm running into a snafu if I try to capture and convert at 352X480.
I convert the file without incident, but when I try to burn the file to disc in either Sonic MyDVD or in Adobe Encore, the resulting disc plays at 352X480 with blank space on either side instead of resizing to the full screen.
I've done my conversion with CCE, TMPG, and Procoder, and I still get the same results. My tool of choice is CCE, and I've toyed around with the settings, but it seems like nothing I do makes a difference. Is this a conversion problem or a problem with the authoring?
Any suggestions?
DrC
Sounds like an authoring problem, or possibly even a problem with your set top DVD player.
Try authoring with TmpGnec DVD Author or DVD Lab. Both have downloadable trials available. If you still have this problem I would blame your standalone DVD player, chcek the disks out on a friends player.
Samsung CRT sp43t7hlx/shi - Resolution problems in w7
By runkz in forum ComputerReplies: 1Last Post: 27th Nov 2009, 02:31 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
sorenson squeeze resolution and fps problems
By phpmysql348 in forum Video ConversionReplies: 7Last Post: 7th Sep 2008, 22:46 -
Resolution problems when converting with FUW
By Malicious in forum DVD RippingReplies: 1Last Post: 8th Aug 2008, 01:02 -
DVD resolution problems / confusion
By Laurels in forum MacReplies: 2Last Post: 5th Jun 2008, 03:57
