  1. I've recorded an episode of MST3K from my laptop s-video into my set top DVD recorder. I then took the DVD+RW onto my computer and ripped it in file mode, giving me a number of separate vobs. The *first* one I edited to remove a bit of blank or dead space in Womble's mpeg-vcr, and it then generates an mpeg output, which I use to author. Well, authoring is no problem, except I do not want to add 4 separate files, I only want 1 file, ie a continous movie.
    So, once it has been recorded (onto a Liteon 5001 clone) in 2 hour mode, what is the best way to go about the process of removing a small portion of what has been recorded, if in the transferring/authoring process I want to avoid having the final file split up?
    Thanks for any advice you can offer.
    Tom
  2. I should clarify that I've tried Ulead DVD Moviefactory 2 and 3m and when importing DVD Video, they both seem to insist on splitting the movie into a numer (~10) of segments. I don't want this; I want one chunk. Failing that, I want seemless playback of the segments, which doesn't seem to occur.
    Of course, I could be using the program incorrectly.
    Tom
  3. Member GMaq's Avatar
    Mar 2004
    Canada
    Thomas Davie,
    You should be able to open your VOB's into the video clips list found in the tools menu in MPEG-VCR(ver.3.14) after you've added them to the list it should save them into 1 contiguous file, if you are using the NTFS file system this should be no problem, even after you have your 1 big file you should be able to scrub through and do any edits then before you save the final file for authoring. hope this helps, Ain't MPEG-VCR great!!?
  4. I'll be damned. Worked exactly like you say, and yes mpeg-vcr is a nifty tool. There are *small hitches*, much less than before, at ~ the 28 minute mark (this is the limit of the individual file size created by my set top recorder I guess), so I'll consider this a victory.
    thank you.
    Tom
