Results 1 to 9 of 9
  1. Finally got a DVD+RW burner a Ricoh MP5120A for just £15 at my local PC World it was just lying there - no manual, not extras, no nothing, just a DVD+RW burner!!
    And BOY was it easy to install!!
    it may not be the fastest burner on the planet but it was sure as hell cheap 8) 8)
    I use DVD shrink to back up dvds insted of those horrible DVD to VCD ripping tools that I used to use...
    I just dont see why people rated them so badly??
    SEE HERE
    A VERY old noob
  2. because it doesnt burn DVD+R's only DVD+RW's can any one tell me if I update to the latest firmware if it will allow me to burn DVD+R's???????
    A VERY old noob
  3. Nope.
    You know what they say, if it seems to good to be true...............
  4. iv seen some like this on ebay
    they are usually customer returns as they dont do everything they are meant to
    sometimes flashing the bios to the latest firmware can fix the problem
    but it could break the drive completely
    is the drive meant to do both +r and +rw
    even if it only writes +rw and plays dvds its not bad for £15
    although if your thinking about making a lot of dvds you can get
    -r disks for £0.50
    whereas +rw are about £2.50
    (after buying a decent dual format burner like a pioneer for £70)
    anything over about 35 disks starts becoming more expensive the way your doing it
    even if your drive only does +rw im sure you could get £30 + for it on ebay not a bad little profit which can be put towards a pioneer
  5. Nice one. i found 2 discarded PC's outside a firm near where i live and BOTH had dvd burners in them. Most of the insides were gone. Both NEC1300a but with no name on the front. nearly wet myself.
    Dave
  6. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Great bargain, well done.
    I wouldn't give two fucks it doesn't burn RW, my firs tDVD burner didn't either and I muddled through for 18 months with it.
    If anyone tells you its too good to be true then they're talking bollocks, it was a great buy.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  7. Originally Posted by Will Hay
    Will
    Will, I think the problem is that it ONLY burn's +RW's
    Rick
  8. Lost Will Hay's Avatar
    Oct 2002
    Oh, shit, sorry, sorry folks
    Thanks for pointing that out Clay
    Will
  9. Originally Posted by Will Hay
    Will
    Who's talking bollocks
