Hey guys. Ok, here's my situation. I downloaded an SVCD movie file and it came as a TAR file. I decompressed everything and it contained an M2V and an SFV file. I couldnt play any of those using any program. I was able to play the M2V file on Nero and it played with the sound and everything. The thing is that I wanted to convert it to MPEG so that I could burn it as VCD and play it on my DVD player. Thanks!
P.S. I tried TMPGEnc and it didn't help.
An sfv file is just a checksum to verify that the file is correct. Normally m2v files are just plain MPEG-2 video elementary streams, but now and then people have given me MPEG-2 program streams with that extension. If it plays with sound then you can just rename it to .mpg and it'll probably be fine.
A man without a woman is like a statue without pigeons. -
are u trying to burn the m2v file and play it on a stand alone dvd player?? if so then this is wat u need... brb i gotta find the right program
TMPGenc Plus thx to ANDYP1 and the ppl here, it was made simple... this is what u want to do open
TMPGenc Plus
the wizard will pop up( i usually click next)
set everthing how u wnat it (Ntsc or Pal) then audio settings click Next
then click browze and select video(audio should come with it)or u can drap it to the drop spot... click next
after rereading ur post this might not b helpful for u cuz this makes it to DVD complaint .. hummm
set ur destination then ur done
Convert/Mux .m2v and .wav into mpeg for DVD??
By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 15:46 -
Muxing .m2v & .ac3 to .TS file
By randronoth in forum Video ConversionReplies: 3Last Post: 21st Jun 2011, 03:21 -
help with ffmpeg args to convert .m4v to .m2v or .mpeg
By rhfritz in forum Video ConversionReplies: 3Last Post: 28th Apr 2011, 13:09 -
using sfv checker
By burgkev in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2008, 18:58 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 12:54
