Hey I got this error and none of the replies on the forum helped me out.
Does anyone knows another way to fix it???
Cheers
If you want an informed reply, you would have to give a lot more information, such as what are you encoding and what settings did you use? It also helps to fill out your computer profile. CBR= constant bit rate: VBR= varable bit rate. ovf frame#?. You might try the doom9, CCE forum, it's more aligned to CCE problems.
faac: frame decoding failed: Gain control not yet implemented
By vthirteen in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jun 2010, 13:16 -
failed dvd deinterlacing with mencoder x264 encoding. help
By link626 in forum DVD RippingReplies: 9Last Post: 3rd Jan 2010, 14:59 -
"Failed to read video frame"
By jva1254 in forum EditingReplies: 1Last Post: 25th Sep 2009, 05:59 -
ffmpeg faac frame decode failed
By fobster in forum Video ConversionReplies: 2Last Post: 28th Mar 2008, 07:10 -
Encoding Failed
By hananke in forum ffmpegX general discussionReplies: 5Last Post: 11th Jul 2007, 06:04
