  1. I keep getting problems when using my conversion programs since I reinstalled Windows.
    My VFAPI Converter will convert my d2v files but CCE wont recognise them as AVI files and I cant get Virtualdub frameserver files to be valid in VFAPI converter.
    Also TMPGENC Encoder keeps crashing no matter what I use it for.
    Cinema Craft Encoder gives me this error.....
    "Read only 0 bytes, while expecting 8 bytes"
    "vinfo_open() failed: *** Could not open the file *** [input file] ***
    [Windows Error Code: 0x2 2]
    Theres definetly a problem somewhere with codecs anyone got a solution?
    I got some stuff to convert.
    USA
    You might use AVIcodec to see what codecs you have installed. You may have too many (conflicting) or not the right ones. With AVIcodec and Video toolbox you can find what codecs you need for the files you are trying to convert.
