i recently bough myself a TV card (compro Vidiomate GOLD) becous i wanted to convert every video i have from VHS to XVID
to try first i used a small cartoon that was about 20 minutes long
so i launched the tv tool and started recording using the following options:
but when i try to play the file with a different player (i used Mplayer & Windows Media Player) the voices are delayed ....
but if i play it using the same player i recorded it (the one from compro) everything is perfect ....
but i trought that the poblems would stop after i converted it into Xvid (using this tutorial)
i installed the programs & the video & audio codecs
when i loaded the movie into virtualdub i got the following error:
since the error was at the beginning and there where still some commercials in front of it, i used "Womble MPEG Editor", wich was recommended somewhere else on the forum, to cut out the commercials.
after i loaded it again the error was gone.
after that i used a bitrate viewer to check the bitrate & configured the virtualdub as the tutorial explains. and i converted it into Xvid
but the voices where still to late ...
and the compro player cant play xvid for some reason .....
anyway, i hope i explained the problem so you can understand it, and thats its in the right forum ....
Greetz
Results 1 to 1 of 1
Ripboot after conversion video & audio sync is out by 1 seconds ???
By yamyoume in forum Video ConversionReplies: 5Last Post: 17th Oct 2011, 15:32 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 23:14 -
Subtitle delay jumping up & down.
By chiappa in forum SubtitleReplies: 0Last Post: 18th Jan 2011, 06:31 -
Delay & Stretch Settings in Mkvmerge
By ThreatTV in forum AudioReplies: 7Last Post: 22nd Sep 2009, 17:05 -
sound delay
By hannss in forum AudioReplies: 1Last Post: 1st Aug 2007, 17:12
