When i try to convert vcd to dvd i got a lot of errors in the .log file.
I dont know whats wrong. Is there someone thats know what to do?
This is the log file:
Starting SVCD2DVD: v1.5.1377.23893
Begin time: 15:02:02
******** Ripping SVCD images to get mpegs
Analysing File: E:\temp\kopps\boat trip.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: mpeg stream contained no scan information (user) data
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
Error getting mpeg details. (probably due to AC-3 audio)
Analysing File: E:\temp\kopps\Bruce Almightyl.mpg
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 420) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #452 (stream byte offset 1048156) -- remaining 420 bytes of stream will be ignored
++ WARN: autopadding requires to insert additional 2292 zero bytes into MPEG stream (due to 1 unaligned packets of 452 total)
Analysing File: E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD1.mp g
++ WARN: unknown user data tag id 0x4d encountered
++ WARN: packet length beyond buffer (pos = 18 + size = 2306 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Analysing File: E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD2.mp g
-->Processing 4 mpeg files.
############### New MPEG File ###############
Horizontal Res: 480
Audio SampleRate: 44100
******** Demultipexing original mpg file
******** Resampling audio from 44.1 KHz to 48 KHz
MPEG Audio Decoder 0.15.0 (beta) - Copyright (C) 2000-2003 Robert Leslie et al.
206879 frames decoded (1:30:04.1), +0.3 dB peak amplitude, 2 clipped samples
Shibatch sampling rate converter version 1.29
frequency : 44100 -> 48000
attenuation : 0dB
bits per sample : 16 -> 16
nchannels : 2
length : 953298432 bytes, 5404.19 secs
dither type : none
clipping detected : 0.137799dB
******** Multipexing elementry streams
Encoding Time 393secs.
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File E:\temp\kopps\boat trip_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File E:\temp\kopps\boat trip_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (E:\temp\kopps\boat trip_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 2496000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (E:\temp\kopps\boat trip_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2767496
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 13019
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
Analysing File: E:\temp\kopps\boat trip_DVD.mpg
INFO: [mplex] Scanned to end AU 135104
INFO: [mplex] STREAM e0 completed @ frame 135104.
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
INFO: [mplex] STREAM c0 completed @ frame 225173.
INFO: [mplex] Multiplex completion at SCR=486378349.
INFO: [mplex] Video e0: buf= 236616 frame=135104 sector=00735508
INFO: [mplex] Audio c0: buf= 1408 frame=225173 sector=00074910
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 1478494668 bytes
INFO: [mplex] Sequence headers: 9382
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 135104
INFO: [mplex] No. Groups : 9382
INFO: [mplex] No. I Frames : 9382 avg. size 40023 bytes
INFO: [mplex] No. P Frames : 36690 avg. size 15631 bytes
INFO: [mplex] No. B Frames : 89033 avg. size 5946 bytes
INFO: [mplex] Average bit-rate : 2188400 bits/sec
INFO: [mplex] Peak bit-rate : 2364800 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 224230
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 151316932 bytes.
INFO: [mplex] Syncwords : 225175
INFO: [mplex] Frames : 225175 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
Horizontal Res: 480
error: frame 15102: CRC check failed
error: frame 18764: CRC check failed
error: frame 105983: CRC check failed
error: frame 198452: CRC check failed
211735 frames decoded (1:32:11.0), +0.7 dB peak amplitude, 152 clipped samples
attenuation : 0dB
nchannels : 2
length : 975674880 bytes, 5531.04 secs
dither type : none
clipping detected : 0.386253dB
Encoding Time 396secs.
INFO: [mplex] File E:\temp\kopps\Bruce Almightyl_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File E:\temp\kopps\Bruce Almightyl_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (E:\temp\kopps\Bruce Almightyl_DVD.mpv)
INFO: [mplex] Bit rate : 2139600 bits/sec
INFO: [mplex] Vbv buffer size : 98304 bytes
INFO: [mplex] Scanning for header info: Audio stream c0 (E:\temp\kopps\Bruce Almightyl_DVD.mpa)
INFO: [mplex] Bit rate : 24576 bytes/sec (192 kbit/sec)
INFO: [mplex] rough-guess multiplexed stream data rate : 2372496
INFO: [mplex] Scanned to end AU 69224
++ WARN: [mplex] No seq. header starting new sequence after seq. end!
**ERROR: [mplex] Sequence split detected 3 but no following sequence found...
Analysing File: E:\temp\kopps\Bruce Almightyl_DVD.mpg
Horizontal Res: 352
Skipped 69720 zeroes at start of file
-00:40:29 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:36:49 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:28:57 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:27:52 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:26:09 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:22:58 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:21:25 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:14:43 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:11:35 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:05:01 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
error: frame 98086: lost synchronization
98086 frames decoded (0:42:42.2), -6.6 dB peak amplitude, 0 clipped samples
attenuation : 0dB
nchannels : 2
length : 451980288 bytes, 2562.25 secs
dither type : none
Encoding Time 185secs.
INFO: [mplex] File E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD1_DV D.mpv looks like an MPEG Video stream.
INFO: [mplex] File E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD1_DV D.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD1_D VD.mpv)
INFO: [mplex] Frame width : 352
INFO: [mplex] Frame height : 288
INFO: [mplex] Aspect ratio : forbidden
INFO: [mplex] Bit rate : 1150000 bits/sec
INFO: [mplex] Vbv buffer size : 40960 bytes
INFO: [mplex] CSPF : 1
INFO: [mplex] Scanning for header info: Audio stream c0 (E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD1_D VD.mpa)
INFO: [mplex] rough-guess multiplexed stream data rate : 1401296
INFO: [mplex] Scanned to end AU 64055
INFO: [mplex] STREAM e0 completed @ frame 64055.
INFO: [mplex] STREAM c0 completed @ frame 106759.
INFO: [mplex] Multiplex completion at SCR=230606262.
INFO: [mplex] Video e0: buf= 228468 frame=064055 sector=00183875
INFO: [mplex] Audio c0: buf= 2080 frame=106759 sector=00035517
INFO: [mplex] Video Stream length: 368311026 bytes
INFO: [mplex] Sequence headers: 4271
INFO: [mplex] No. Pictures : 64055
INFO: [mplex] No. Groups : 4271
INFO: [mplex] No. I Frames : 4271 avg. size 15474 bytes
INFO: [mplex] No. P Frames : 29894 avg. size 6528 bytes
INFO: [mplex] No. B Frames : 29891 avg. size 3581 bytes
INFO: [mplex] Average bit-rate : 1149600 bits/sec
INFO: [mplex] Peak bit-rate : 1148000 bits/sec
INFO: [mplex] BUFFERING min 76134 Buf max 136193
INFO: [mplex] Audio stream length 71742724 bytes.
INFO: [mplex] Syncwords : 106761
INFO: [mplex] Frames : 106761 padded
Analysing File: E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD1_DV D.mpg
Horizontal Res: 352
-00:33:29 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:33:01 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:32:48 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:28:51 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:28:48 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:19:32 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:11:29 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
-00:08:35 Layer II, 224 kbps, 44100 Hz, joint stereo (I), no CRC
94026 frames decoded (0:40:56.1), -6.0 dB peak amplitude, 0 clipped samples
attenuation : 0dB
nchannels : 2
length : 433271808 bytes, 2456.19 secs
dither type : none
Encoding Time 178secs.
INFO: [mplex] File E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD2_DV D.mpv looks like an MPEG Video stream.
INFO: [mplex] File E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD2_DV D.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD2_D VD.mpv)
INFO: [mplex] Scanning for header info: Audio stream c0 (E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD2_D VD.mpa)
INFO: [mplex] STREAM e0 completed @ frame 61409.
INFO: [mplex] STREAM c0 completed @ frame 102340.
INFO: [mplex] Multiplex completion at SCR=221061120.
INFO: [mplex] Video e0: buf= 204756 frame=061409 sector=00176294
INFO: [mplex] Audio c0: buf= 2080 frame=102340 sector=00034047
INFO: [mplex] Video Stream length: 353107234 bytes
INFO: [mplex] Sequence headers: 4095
INFO: [mplex] Sequence ends : 0
INFO: [mplex] No. Pictures : 61410
INFO: [mplex] No. Groups : 4095
INFO: [mplex] No. I Frames : 4095 avg. size 15114 bytes
INFO: [mplex] No. P Frames : 28658 avg. size 6658 bytes
INFO: [mplex] No. B Frames : 28658 avg. size 3503 bytes
INFO: [mplex] Peak bit-rate : 1179200 bits/sec
INFO: [mplex] BUFFERING min 71447 Buf max 144515
INFO: [mplex] Audio stream length 68773156 bytes.
INFO: [mplex] Syncwords : 102342
INFO: [mplex] Frames : 102342 padded
Analysing File: E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD2_DV D.mpg
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing E:\temp\kopps\boat trip_DVD.mpg...
!!!: GOP is not closed on cell boundary
Creating VTS #2
-->: VTS 02
STAT: Processing E:\temp\kopps\Bruce Almightyl_DVD.mpg...
Creating VTS #3
-->: VTS 03
STAT: Processing E:\temp\kopps\KOPPS.SWEDISH.SCREENER_SVENNE.CD1_DV D.mpg...
!!!: unknown aspect ratio 8
Closed Thread
Cutterman Errors
By TwoMutts in forum EditingReplies: 2Last Post: 9th Apr 2009, 16:27 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
Disc C2 Errors
By kidcash in forum MediaReplies: 1Last Post: 5th Jul 2008, 12:56 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53 -
Errors on startup
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 06:14
