Hi,
Hope this is the right forum. I recently had to rebuild my XP box. I have a sony dru500a. After loading the software on their disks, I followed their procedures for upgrades. (help->check for updates) . Instructions require the use of their update manager.
After downloading the most recent update manager 'Sonydrive_sum29.exe', I get the following error when trying to upgrade. 'The program was unable to connect to the update server, please check your network connection'. The network connection is fine, as evident by this post
Recordnow version: 4.50 Build 450B28a.501 (SNV)
Can anyone show me a light at the end of the tunnel?
Thanks!
Results 1 to 10 of 10
not sure if this helps but i have record max now version 4 and got a link to the free upgrade to 4.5 which is a full install it uninstalled 4 first .and i have the same burner as you and after install it could not find sony and i had to reboot several times before it did here is the link they gave me
http://downloads.stompinc.com/support/stprnm450v.exe -
I have RecordNow DX version 4.61 installed, per a previous update made available to Sony users that received the bundled version. Sony's website currently indicates that a free update to 6.71 is available, and provides a link to a Sonic page:
http://sony.storagesupport.com/dvdrw/recordnow.htm
http://www.sonicjapan.co.jp/oem/sony/rnupdate_en.html
I also went through the step of loading the Update Manager, and am getting the same error of "...unable to connect to the update server..." when attempting to use the Help | Check for Updates option.
ZoneAlarm indicates that 63.151.110.101 is the destination site when attempting the update. If I ping this address, it times out. Tracert indicates this resolves to updates.sonic.com, and after 15 hops times out.
arhouse -- have you got any further with this? I've created an incident with Sonic, so will see what we get back... -
As a follow-up to my previous post...
I actually did get a reply from Sonic...several days after submitting a support request. They sent me an email with the correct Sonic URL, with the necessary user name and password. I was then able to download the update of RecordNow v6.7.1, which is free to all Sony DVD±RW owners. You can send me a personal message if you still need the info.
I haven't installed the update yet, as I would like to first verify if the new version is better or worse than v4.61. -
It is possible. Not likely though. I wonder if they might have changed the IP Address of their update server though, and it is hard coded to check their old IP Address or something like that. I have seen problems like this in the past when companies have reconfigured their DNS server.
If in doubt, Google it. -
Originally Posted by LetsRip
reading the 'features' of the newer version -- it has less features than the older version ...this is an update ?
!!Please help me!! Windows 7: Windows Update in not working
By flashandpan007 in forum ComputerReplies: 3Last Post: 23rd May 2011, 20:14 -
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
megui question, stopped working after WHS update
By runLoganrun in forum Video ConversionReplies: 4Last Post: 14th Jul 2010, 16:51 -
Free Download Manager not working
By CSULB71 in forum ComputerReplies: 5Last Post: 27th Apr 2008, 15:54 -
record now update not working
By limemarionette in forum DVD & Blu-ray WritersReplies: 2Last Post: 3rd Aug 2007, 12:13
