Can I use DVDShrink not as a backup or copying tool, but to make a bunch of MPEGs (or their resulting VIDEO_TS folder) that I've made (but are too big) fit on a recordable? I'm relatively happy with MyDVD even though everyone bags it, but I believe it does encode imported MPEGs at 8000 CBR and with PCM audio, so these are what I want to shrink. Does it only compress the vision of video files, or will it shrink the PCM audio as well (with MPEG or AC3).
Will it effectively turn my CBR video into VBR?
I know a better solution is the TMPGEnc coding/authoring bundle, but I haven't got the OK to spend any more on this hobby right now and I'd like to see if I can achieve what I want to do with what I already have + freeware.
no....ull need to make the vcd to dvd using a dvd tool to convert from mpeg/vcd to dvd, u could then author the resulting mpegs-dvds to a dvd with dvd-shrink.
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 2nd Dec 2010, 00:07 -
dvdshrink for bluray
By xenotox in forum Blu-ray RippingReplies: 20Last Post: 18th Jul 2009, 10:10 -
Help wanted for DVDShrink 3.2
By _beavis_ in forum Newbie / General discussionsReplies: 13Last Post: 6th Feb 2009, 01:11 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 18:17
