Hay guys. just ripped a dvd to .d2v using dvd2avi.as most people know i then opened it in TMPGEnc plus to encode it to a mpeg.I have no problems loading the the .d2v file but wen i come to the encode screen it says unsuported! wen i check the source range its says "no video loaded" but it loaded the video at the the start of the wizzard.any help i would be good.by the way im new to all this! HELP.
Cheers
have you moved or deleted the source dvd vob files? the small d2v just points to the vob files.
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Simple problem - stretching video files.
By heartburn88 in forum Video ConversionReplies: 11Last Post: 17th Jun 2009, 15:21 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
A simple but annyoing computer problem...
By Super Warrior in forum ComputerReplies: 2Last Post: 23rd Oct 2007, 22:47
