hi,
i have an ati aiw 9600 card and so far i have only been capturing with ati software as svcd mpeg2 format, but i 'm trying to capture as avi and the quality of the avi from this software's capture is not very good so i'm switching to virtualdub
now, i have already installed huffy and picvideo mjpeg codecs but in the compression codec list invirtualdub, those r not there; i wonder if anyone has seen this problem
thanks
with the huffy, i rightlick on the ini file and click install (per its attached instruction); the other one is just regular .exe install; it has 3 diff. codecs in the install file
Have you checked to see if it is in the System32 folder? Does your system prevent writing to the registry?
Hello. -
no i havent done that, but when i went to control panel -multimedia -video codecs and i see them in the list of installed codecs; so i dont really unerstand why they r not seen in virtualdub
btw, i have an ati aiw 9600; i have directv so there's no signal from the analog tv tuner;i do get the signal from the svideo connection to the directv receiver; i dont know if this bit of info makes any difference or not.
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2011, 00:17 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 21:19 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 11:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 21:59 -
Virtualdub capturing resolution problem
By bloodshed in forum Newbie / General discussionsReplies: 3Last Post: 15th Jan 2008, 13:07
