is there a tool that will tell you wether your mpeg is pal or ntsc..when i load an mpeg into gspot it says n/a on all the settings...thanks for any input
Hi catdaddio6,
Use AVICodec on the MPG file. It won't actually state whether it's PAL or NTSC, but it will give you sufficient information to be able to work it out (i.e. resolution, fps etc.).
See the blue DVD link in the top left of the page for the full specs for DVD (both NTSC & PAL).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Does anyone know any tool to check if files 'mpeg-2' are faulty?
By sgbd in forum Video ConversionReplies: 8Last Post: 13th Sep 2010, 21:12 -
cmd line tool to join two mpeg-2 files
By nighthawk2018 in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2010, 22:13 -
Need mpeg-1 to VCD tool that splits
By anadiner in forum Authoring (VCD/SVCD)Replies: 14Last Post: 4th Dec 2009, 04:24 -
Convert AVI to MPEG-1 without losing quality: What tool?
By GeekyChocolate in forum Video ConversionReplies: 8Last Post: 28th Mar 2009, 16:42 -
tool to convert dvd to mpeg-1
By sumeshkri in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 03:29
