Hi guys and gals,
I recently downloaded 321 Gone to get rid of the pesky warning label that is part of the 321 Studios software DVD XCopy Xpress. It worked fine for the first few DVD's I made, then it just quit working. I tried deleting it and re-downloading, and re-installing it but that didn't work either.
Anyone know what I might be doing wrong?
Thanks in advance, Randy
I cannot help you with getting 321 gone working, but I can suggest you take a look through the guides to the left. There is one called "Better way to remove 321 disclaimer" or smoething like that. That may help you.
For what it's worth, have you thought of trying a couple of freeware programs like DVD Decrypter and DVD Shrink instead ?If in doubt, Google it. -
Yeah, shrink is the bomb, copys the whole DVD with compression that you can set.
I use the MOST compression on trailers, extra features, turn off foreign subtitles, and sometimes 5.1, and the movies reaches 6-70%, which looks wonderful.
I then use nero to burn.
Total time from start to finish can sometimes be 18 minutes.
Does anyone know where to find 321 media classic
By stadelbauer in forum Newbie / General discussionsReplies: 1Last Post: 17th Apr 2012, 22:43 -
testing 321
By bendixG15 in forum TestReplies: 10Last Post: 26th Jan 2012, 07:36 -
Issue With D-Link DNS-321 & Seagate 2TB Seagate Barracuda
By RKelly in forum ComputerReplies: 0Last Post: 25th Dec 2010, 22:52 -
Bose 321 GSX How to make it region free?
By wouter3 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Nov 2008, 08:23
