  1. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    Hi all...
    Anyone know of a good way to clean the inside of a DVD writer?
    Is there anything special out there that does a good job?
    May 2003
    I use a dvd lens cleaner and it works great I use it on my dvd burner and my dvd players and stand alone DMR-E80H..And finally the one I use is called discwasher dry system, you can find them at circuit city and bestbuy...
  3. Do a forum search - there are a load of posts regarding this.
    Be very sure you need to do what you're talking about, since there are risks involved and most people never have to clean a lens in their life unless they're heavy smokers or live in a very dirty, dusty house (in which case they will probably die from silicosis or asthma before the drive does).
  4. Banned
    Oct 2003
    Americas
    You can open your DVD player, vacum it if necessary and clean the laser pickup lens with a cotton swab. I used a bit of a lens cleaning fluid (optical, for coated lenses). No issues. Worked fine.
    One remark, if you have any reading/writing problems I doubt if this is gonna fix it unless there was in fact a speck of dust on the lens.
