  1. I need to search a string opened from a text file to see if an inputted number matches a value with the file.
    so;
    inputnum as integer, numfound as boolean
    inputnum = val(txtinput.text)
    open alreadyusednums.txt for input as #9
            do until numfound = true
    'what do i do here
    'once found, numfound = true
            loop
    close #9
    alreadyusednums.txt would look like this
    3545
    25
    645
    234
    7777
    223
    7677
    2
    3443
    334
    4535
  2. Member SaSi's Avatar
    Jan 2003
    Hellas
    Assuming you are reading the file to find numbers matching "inputnum", then the reading code should be like:
    Dim s as string
    Open alreadyusednums.txt for input as #9
    Do Until numfound = True
    Line Input #9, s
    if isnumeric(s) Then
    if val(s) = inputnum then numfound = true
    endif
    loop
    The If Isnumeric(s) line is there in case your .txt file contains an empty line, which would cause val(s) to generate a type mismatch error.
    The more I learn, the more I come to realize how little it is I know.
  3. I actually found a way to do it after I posted, came back here in about 30min and you had found a better way!
    that was fast
