i need to crop my video becase the top half is black and takes up to much screen....i would like to just cut that part right off...how do i do it?
Results 1 to 9 of 9
It would help if we knew what file format you are using. Virtual Dub mod has a null transform filter that do both AVI and MPEG files, but you have to frameserve the MPEG file to an MPEG encoder to save. TMPGEnc Plus can do most formats with its Clip Frame function under Settings-->Advanced tab.
Hello. -
i have virtualdub version 1.5.1 AND TMPGENC plus 2.5 can i do it on either of these?i have mpeg files
Yes. With Virtual Dub, you have to framserve the MPEG file to TMPGEnc Plus to save it as an MPEG after you crop it. TMPGEnc Plus can do it with just its main program
Hello. -
Use all the buttons you need to remove what part of the video you do not want to see. Select OK, then name your output file, press Start on the main program screen. It will re-encode the video, I do believe.
Hello. -
i see....any program that is any quicker then that?its saying hour and a holf till its done..thanks
I have heard the Mainconcept and CCE may be quicker, but I have never done any speed tests myself.
Hello.
How to crop a video?
By toqi786 in forum EditingReplies: 22Last Post: 27th Jul 2012, 22:37 -
Crop a Video
By jjis in forum EditingReplies: 3Last Post: 21st Jan 2012, 13:27 -
How to Crop Video
By xiaomanda in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2011, 10:24 -
Crop a video?
By Cined in forum EditingReplies: 1Last Post: 29th Apr 2010, 08:50 -
Crop video
By weta in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2009, 16:27
