Does anyone know if someone manufactures a capture card that will take all 3 composite RCA connections from a VCR. Meaning both the audio red & white, as well as the video yellow. I don't know what the standard is, I just thought it would be nice if I could hook it all up on one card and then capture from VHS/VCR.
Thanks for your input, Randy
There is plenty of those, I have tried only USB's, the first one was the DAZZLE 80 US70$, which is bad (maybe the software). Returned
I am using now the Pinnacle Moviebox USB US200$(Not the DV Model)
So far so good, just archiving family videos from 8mm, Hi8 and VHS, but I am a newbie and other users may tell you different stories.
IN any case, whatever you choose, get it from a vendor that accepts returns easily. Specific Card performance may be acceptable for me but not for you. In addition of this you may struggle in capture depending upon you PC's processor (Intel/AMD), speed, M<emory, Hard Drive Space, etc. -
Thanks for the tip. Do you use a USB 2.0 or a 1.1 port to plug your Pinnacle Moviebox USB etc. into?
Thanks, Randy
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
ATI or NVIDIA capture card for VHS?
By Smile_M in forum Capturing and VCRReplies: 1Last Post: 13th May 2010, 06:43 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
Best S-VHS To best Capture card
By samturner01 in forum Authoring (DVD)Replies: 7Last Post: 15th Feb 2008, 18:00 -
suggestion for vhs capture card
By abbymat in forum Capturing and VCRReplies: 8Last Post: 28th Jul 2007, 00:57
