I have some divx movies that have very very low volume, I had to turn my volume to max to be able to hear it. Is there a way for me to up the volume using a program or something? Thanks.
hmmm,that program can't put it into my video? I can only save it as .wav, .midi, etc.
How would I implement that into my video? -
Virtual Dub mod. Load the video, select Audio (Full Processing mode)-->Wave audio. Select your new wave file.
Hello. -
You've been a great help so far but I have one more problem... How can I install lame codec? I tried putting the lame_enc.dll in c:\program files\goldwave, c:\windows\system, and c:\windows\system32 but whenever I try to save the editted audio file as .wav using lame codec it doesn't work. Kept on saying it doesn't detect the codec. You know why? Thanks.
I only use the Lame codec in TMPGEnc Plus. I never tried using it in Gold Wave. But if you want to try, go to the Lame website for more info. Or, you can have TMPGEnc Plus encode your maximized wave file, by loading it as audio, and selecting the lame codec as a environmental setting in Options.
Hello. -
I tried that with dub and it works great, thanks a lot. Dub seems to like the lame encoder, gold doesn't... =/ but i got it working thanks again.
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 12:39 -
Bumping Up the Volume
By solarblast in forum AudioReplies: 1Last Post: 10th Dec 2008, 23:46 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 20:19 -
volume increase
By natty in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2008, 11:08 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
