I asked this question once before but i cant remember where it was at. Can anyone please tell me how to adjust this setting once again. After only a couple of minutes of capturing it will cut off and give me this error messageavioutput. the paramater is incorrect). Any help would be appreciated.
thanks alot!!
<font size=-1>[ This Message was edited by: BOXINGJUNKIE on 2001-10-25 18:23:25 ]</font>
Results 1 to 9 of 9
hey thanks for the reply truman. im still having the same problem though. i did what you said. goto capture-enable multisegmant captue. it will only let me put a check mark by it. it wont let me set the max to anything. nothing opens up. what exactly did you mean by filesize of each segment to max 2GB. i dont know what you mean by segments. also you said that tmpgenc wont work with 2gig files. do you mean it wont work with a file over 2 gig? if you can tell by my username, i love boxing. i am trying to put some of the fights that i have on vhs, to vcd's. so some of the files will be really big. i just started reading about this stuff a week ago so i dont to much about it yet. please explain it for a beginer. thanks for your patients. any help is greatly appreciated.
<font size=-1>[ This Message was edited by: BOXINGJUNKIE on 2001-10-25 23:47:21 ]</font> -
Long time ago, that I used VirtualDub to capture. Yes, just set a check mark, the default segment size is ~1,9 GB, so you don't care about that. As far as I remember, you can change the segment file size at capture> disk (or drive or something like that).
If you enable multisegment capture, the file wont be saved as one big file.avi, but as several small pieces (file00.avi, file01.avi, etc).
When you edit it later, just open the first segment in VirtualDub. It will load all segments, no matter whether you save it as a new avi or you frameserve it to a MPEG encoder. -
when i go to captue the only thing under it is disk I/O. the chunk size is preset at 512k. and chunks in buffer is set at 2, for a total buffer of 1024k. does this sound like what you are talking about. if it is what should i be setting these numbers at in order to get this big files captured. also when this error message comes up it automaticaly shuts down the capture and wont let me capture anymore. so im not sure if it is still capturing in a smaller piece. i hope i explained myself. i hope anyway.
thanks again for all your help. -
I don't have VirtualDub in front of me, I hope I can explain it correctly.
Start VirtualDub, select file> capture -> a new window pops up
Set audio> compression, video>format, video>compression, capture> preferences (drivers, framerate etc.)
Select capture> check enable multisegment capture.
Start capture video.
The file will be saved as file00.avi, file01.avi etc. automaticaly, just due to the "enable multisegment capture" check mark. If you don't check it, VirtualDub shuts down after saving 4 GB.
Hope this helps.
yes that is exactly what i did. i checked enable multisegment cature but it still shut down at 4GB. and yes it did save it as file00 but thats all there is there was no file01 or file02. it just stops capturing. i know you said you dont use virtualdub anymore, is there another program that you use that is better? just wondering.
thanks again
i tryed to open the file that i just captured in virtualdub, in TMPGEnc, and it says its cannot open or unsupported. is this because it shut off and there is not file01? i dont know just wondering.
thanks again
<font size=-1>[ This Message was edited by: BOXINGJUNKIE on 2001-10-26 00:42:35 ]</font> -
At the moment I do not capture at all.
Well, I searched vcdhelp.com and found this:
http://www.vcdhelp.com/faq.htm#spillsystem
check it out. -
hey thanks for all your help truman. i think this might be exactly what i need. i will give this a try and let you know if it works.
thanks, much appreciated
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
