I am trying to upgrade my Pioneer 107D firware using the DVRFlash utility with the latest firmware. The readme file says I should load this via the DOS Prompt. When I load MS-DOS and entered the information as instructed....DVRFlash -vf E: R7100007.110 R7100107.110....I get a Pioneer "disclaimer" come up asking if I agree. After entering Y for "Yes", I get a message "// sptxOpen.CreateFile: x2 (2) The system cannot find the file specified. Could not open device \\.\E: I have tried several times, same thing comes up. ANy ideas on what I should do to get this firmware to load?
I am using Windows 98SE with Pioneer 107D (OEM Version)
Is \E: your DVD drive? You may need to change that to the proper drive letter.
Thanks,
Pete -
you need to edit the .pif file so it is pointing to the correct drive.
I believe by default it is H:
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Pioneer BDR-205 requires HD video card to work??
By lafjax in forum DVD & Blu-ray WritersReplies: 4Last Post: 1st Jan 2010, 12:51 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Pioneer DVR-107D mistakes certain DVD+R/DVD-R discs as "blank CD"
By litmus in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th Sep 2007, 14:38 -
TYG03 burns at 18x in DVR-112D, only 4x in DVR-107D
By mikewillnot in forum MediaReplies: 1Last Post: 15th May 2007, 17:28
