This is the second time this has happened to me using freshly encoded mpegs. I've converted DiVX AVI files to SVCD using MainConcept MPEG Encoder, yet each time the application just stops. Ive let it run overnight for shits and giggles, but that didnt work.
When it gets to the "Resampling audio" portion of the conversion, it just stops. Nothing freezes, just stops.
Starting SVCD2DVD: v1.51.2.0
Begin time: 10:30:58 AM
Analysing File: C:\DVD_RIP\InAmerica\america.mpg
-->Processing 1 mpeg files
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 560
Standard: NTSC
Audio SampleRate: 0
******** Demultipexing original mpg file
(Total size: 3633MB, Duration: 00:07:17, Rate(MB/Min): 497.83)
******** Resampling audio from 44.1 KHz to 48 KHz
More info,
What I had was a 700 meg DiVX file, converted to one big mpeg2 file with Main Concepts encoder. This didnt work.
So I re-encoded the DiVX file to SVCD and split it into 3 parts. Aparently this worked fine. Yet the same process converting dozens of Ren and Stimpy DiVX files to SVCD did not work.
All default by Main Concept, 44khz 480x480 x30fps. -
AC3 input is not supported... until the next version.
Losslees Audio on DVD player without resampling
By ITISRAVI in forum AudioReplies: 7Last Post: 23rd Jun 2011, 00:28 -
Resampling audio
By siluet in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2009, 12:24 -
Resampling Audio
By Germanicus__ in forum AudioReplies: 18Last Post: 19th Jun 2009, 04:55 -
Audio Issues: Resampling, etc.
By tacman1123 in forum ProgrammingReplies: 3Last Post: 21st May 2008, 07:36 -
Audio sync issue even when dynamically resampling audio
By purpleman in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2008, 11:18
