I know that the noise is invisible when the video is watch on TV due to the overscan, but when the video is watch on computer it's boring.
I don't want to crop the video because I must re-encode it to put it on a dvd, i just want to apply "black color" on the noise...I've read that it's possible but I don't know how to do it and with which software.
If I'm oblige to crop the video, which software can add black to resize the video without re-encode it ? I acquire video directly in mpeg2 (520x576) with ATI MMC and I can crop it directly but the size is 672x528 !
If it's possible I would prefer use free software...
I hope that you can help me.
thanks
You want the impossible with free software . Ambitious
ANY changes to the pictures in the video will require re-encoding
Give up. -
MMC, I believe starting with version 8.0, will crop overscan and overlay with black IF type is set to DVD-MPG.
SFAIK it is not possible to do with an existing MPG without re-encoding. -
Nelson is right.
Make sure you select MPEG2-DVD or MPEG2-SVCD when you select "record cropped video" (as opposed to generic MPEG-2). MMC will then add black bars to keep the resolution compliant. -
Does anybody know how much it crops , how much border it adds, or how
to change the settings ? -
On the older MMC it cropped to 672x448, this could be changed using percentage values with Stinky's RegTool, I think it would snap to multiples of 4. Haven't tried the tool on newer MMC.
thank you very much for your advices. I will try to update my version of MMC from 7.7 to 8.x
please list the virtualdub filters to remove vhs tape video noise
By perfection in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2020, 13:45 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
Looking for a filter to mask out white specs in video...
By Deter in forum RestorationReplies: 8Last Post: 2nd Aug 2010, 14:36 -
Best way to Mask out Betamax video dropouts using hardware?
By Deter in forum RestorationReplies: 3Last Post: 10th Mar 2010, 12:02 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57
