How can I rip only the audio track from a DVD into a WAV file?
Results 1 to 13 of 13
DVD Decrypter
IFO mode
Rip by chapter
Stream rip
set to demux the audio stream you want
If no PCM/WAV stream,convert ac3 to wav with Heahac3he -
If you're too lazy to follow any of the guides or have a reason to automate the process, DVD2ONE has announced a new product that does this.
It delivers a DVD that contains AUDIO ONLY that plays 16bit on all DVD players (not a DVD AUDIO 24bit type )
www.dvd2one.com
DVD+Audio Creator is what its called -
Wulf109, can you elaborate on your explanation for me? I followed what you wrote and used DVD-Decrypter on a DVD that had PCM. I ended up with a VOB that contains audio only (I guess that is good). How do I convert that VOB to MP3?
Also, I did look for a guide to follow and found one here, but its link hasn't been working for a few days so I can't use it.
Thanks for any help. -
you could rip the whole dvd to your hard drive with smart ripper then use TMPGEnc plus to split to seperate audio and video streams then use a program like goldwav or ffmpegGUI to convert to .wav format just remember to go from 48 to 44 on your audio encoding if your going to be playing your .wav files in a standard CD player.
that's not what the poster was interested in. this prog DOES NOT rip. it is a dvd audio disc creator. it takes wav files and encodes it to dvd audio specs if you wish. but it's not a ripper.If you're too lazy to follow any of the guides or have a reason to automate the process, DVD2ONE has announced a new product that does this.
www.dvd2one.com
BTW i am kind of suspicious of the prog. claims the dvd audio disc it creates is much higher quality (when set to the highest setting) than the original CD from where the wav files originated. kinda like CREATING ENERGY. -
Interestingly I did this recently but only wanted one song off the DVD. I used DVD2AVI to work out which vob file it was one and ripped that one, creating the wav file from the Dolby Digital Decode option. I then opened the wave file with Adobe Audition, found the song I wanted and moved that segment to a new track and then output it as a WMA file for my portable playerOriginally Posted by goldenhawkofky
Larry -
I used DVD Audio Extractor
https://www.videohelp.com/tools?tool=547#comments
I was able to leave the orignal DVD in the drive and select the individual track(s) I wanted. Has MANY option sof what kind of audio file you want to make from it.
Hope that helps
Plus, it was VERY fast. A 60 minute DVD was converted in 8 mintues with all the tracks becoming individual files, which you can option to do or not. -
Hello again guys. I serach the forums and found this recent thread, so I'd figure I'd ask my questions in here to get some faster responses. Here's what I want to do:
I want to basically compile a CD audio collection of my favorite Quotes, Lines, Sounds from my personal DVD collection into MP3's or WAVs (doesn't really matter to me, whichever is easier) and burn them onto a disc. WAVs would be better so I can listen to the CD in a regular CD player (non-MP3 player), but I know that MP3s would save space. I know that I can probably convert either or into either format - not a big deal. I am just curious on how I would be able to do this??? I don't want a whole chapter of audio, JUST a quote or a COUPLE of lines. So what would be the BEST program(s) to use for this??? I already have an audio editor/mixter (Acustica - I think is what it is called), but what would be the best process for doing something like this with almost 200 DVDs???
I was looking at DVD Audio Extractor V1.1.6. This seems to do the job as far as ripping the audio tracks by Chapters. I am guessing that I would just find the chapter(s) that had the quote(s) or lines that I wanted and then just rip those audio tracks. Looking at the program, it seems that it would let you then convert/encode the ripped audio Chapter into a WAV or MP3. Finally, I am guessing that I would use my Audio Editing program to open up that saved WAV/MP3 audio chapter and then find the quote/lines that I wanted and cut/delete the stuff I didn't want to finally save it as an MP3 or WAV. It seems like it would take a long time, but there doesn't seem to be any easier or faster ways of doing this.
It would be appriciated if anyone could comment on this or add any kind of info or help on this... Thanks.
Dallas22
ripping audio from a dvd
By tduck7 in forum AudioReplies: 2Last Post: 17th May 2010, 15:29 -
Ripping audio from a DVD
By VenusAndMars in forum AudioReplies: 5Last Post: 10th Apr 2010, 14:39 -
Ripping Audio off DVD
By alimustafakhan in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jun 2009, 17:28 -
Ripping Audio from a DVD
By j_p in forum AudioReplies: 4Last Post: 18th Mar 2008, 15:55 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 03:06
