Is it possible to lower the bitrate of a VCD file (.mpg) so it can fit on a CD. The file is currently 800mbs (Swordfish. Will lowering the bitrate make it under 700mbs? And if this is possible, what software can do this?
Thanks!
The file is still too big to be fit on a CD. (The file is 800mbs. It will not fit on a 700mb CD)
Is there any programs that will lower the bitrate of the MPG and reduce the size???
Any help is appreciated!!!
THANKS!!!! -
Reencode with your favorite MPEG encoder if you like, but kimpan is right, you can fit 800MB on a 80 min(700MB) (S)VCD without overburning.
Lowering the size of video and editing
By imenica in forum Newbie / General discussionsReplies: 8Last Post: 21st Sep 2011, 15:23 -
Lowering contrast in H264 file
By carlmart in forum Video ConversionReplies: 13Last Post: 19th Jun 2010, 09:33 -
Avi lowering Frame rate and audio
By vipertongn in forum EditingReplies: 8Last Post: 14th May 2008, 04:31 -
lowering a framerate
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Feb 2008, 12:18 -
Does lowering the maximum bitrate, gain more space?
By Wile_E in forum Authoring (DVD)Replies: 2Last Post: 23rd Oct 2007, 21:37
