When I try to burn two 700 mb mpeg files as a dvd video, it starts to encode but it will just stop in the middle. There is no error messages, it hasnt frozen, the progress bar just stops, and it takes forever to even encode the little bit it does. Any suggestions?
the file is an mpeg-layer 1, I dont know about the audio. My computer is a 700 mhz (flat panel 15") 40 gig hard-drive, 256 mb memory. The DVD-RW is an external Hi-Val (in an external casing).
for kicks, try using sizzle.
see if it properly makes yoru dvd image, if so burn that and your good to go
Bad sectors when burning DVDs with Toast Titanium
By Akominatus in forum MacReplies: 3Last Post: 5th Apr 2011, 12:46 -
Menu button selection order in iDVD vs. Toast 10 DVDs for MAC
By HowardNeedsHelp in forum MacReplies: 0Last Post: 29th Aug 2009, 12:06 -
Toast 9, Verbatim DVD-R DL DVDs... HELP!
By Paul ND in forum MacReplies: 13Last Post: 4th May 2008, 03:37 -
Dropped frames (or jerky video) from Toast DVDs, but not Visual Hub
By chrjohns in forum MacReplies: 3Last Post: 19th Feb 2008, 09:37 -
Why can't I copy to DOUBLE LAYER DVDS using Toast 7.0.2?
By maccaneer in forum MacReplies: 3Last Post: 28th May 2007, 17:19
