I have started a huge project in premiere pro and recently discovered that a few large avi files have been captured in 32khz format which is useless for DVD.
What is the best way to convert them to 48khz in order to achieve compatabilty.
Cheers
Si
In addition to the above i have realised that the premiere project is set at 32khz. AHHH! Can this be changed.
Help me please! -
Sikburns,
2 softwares:
- either Adobe Audition if you bought the video collection or
- SSRC, free software you can download on the left. Download the Besweet GUI that manages SSRC and makes it even easier.
How to do it:
- Once you have finished your project with PremierePro, export the audio track only in a .wav file.
- Resample the .wav file with either of the 2 softwares mentioned above.
This is what I do all the time and it works like a charm.
192 vs 96 vs 48 vs 44.1 KHz?
By therock003 in forum AudioReplies: 22Last Post: 19th Nov 2012, 10:55 -
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29 -
32khz mpeg to 48khz how to ?
By Videodream in forum Capturing and VCRReplies: 12Last Post: 4th Aug 2008, 10:11 -
capture of S-Video and PCM 44.1 kHz at the same time ?
By nidi in forum Capturing and VCRReplies: 16Last Post: 23rd Apr 2008, 15:16 -
24/96 khz
By mikee55 in forum AudioReplies: 3Last Post: 10th May 2007, 11:39
Cheers
