  1. Is there some way to set the default settings in the wizard?
    I like to use wizard mode since it calculates the kbits/sec internally.
    The problem is there are some settings which I always set the same, and I dont want to have to do it manually every time...
    I tried saving the default project but it doesnt use the same setting for the wizard.
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi yepyep,
    1. "Load" (button in bottom right of window) the default settings template you want to tweak.
    2. Now click on "Load" again and load the "unlock.mcf" template in the "Extra" directory. This will retain the originally loaded settings, but allow you to tweak them by clicking on the "Setting" button (also bottom right).
    3. Tweak as required and then, from the main window, click "Save" and save to the "Template" directory - REMEMBER to give it a unique name, or you could overwrite the default.
    When you open the "File -> Project Wizard", it should appear under a section titled "Other".
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Ahhh thanks.
    The Loading the Unlock is important. One of the settings in the one I tried before must have been preventing it from displaying in the wizard.
    This is going to save me a little time
    Thanks again
  4. Member daamon's Avatar
    Melbourne, Oz
    No problem. Glad to be of help...
    Carpe diem.
