When i make a DVD what attention do i need to pay to bitrate? how is it important and what settings should i be using? tnx
Hey, Don't I know you from another post...?
The higher the bitrate, the better the quality, and the bigger the filesize. Filesize is dependent only on bitrate and running time of footage in seconds.
Depends on the quality of the source, and what you're aiming to output (VCD, SVCD, DVD). If you're footage is less than around 90 mins, you can use a decent bitrate of at least 6,500kbps. If it's really short, you could get away with CBR. If disk space is sort of tight (especially if there's fast motion scenes), you need to use VBR....and what settings should i be using?
Or, in short, I think you're gonna soon see that you've opened a can of worms and will nead to learn a fair bit and it's not as easy as "shoot, edit, burn".There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
DVDRHelp Bitrate Calculator would be useful for you.
If you're gonna go for DVD files, look into demuxing the audio from the source and compressing to something like AC3 (NTSC & PAL) or MP2 (PAL, but probably OK in NTSC land even though not in the NTSC spec).
This will mean that it takes up less room on a finite-sized DVD disc, and so leaving more room (i.e. higher bitrate, hence better quality) for the video part of the footage.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I hope there's a "Originally Posted by DVDnewbi
" or a " :P " after there...
Carpe diem.
Joboshare dvd copy produced a bunch of files I dont understand
By rocks911 in forum DVD RippingReplies: 1Last Post: 31st Aug 2011, 22:38 -
I dont understand .mkv files at all!
By InfernoParadox in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 01:21 -
Config new PC - importance of CPU speed, L3 cache, RAM?
By OldAmateur in forum ComputerReplies: 19Last Post: 29th Jan 2010, 14:47 -
Dont understand message before laptop restarts?
By Tbag in forum ComputerReplies: 14Last Post: 24th Feb 2008, 06:56 -
The Importance of Backups
By Soopafresh in forum ComputerReplies: 11Last Post: 9th Sep 2007, 18:31
