I am going to have a website with high quality clips for download and want to know what format they should be in so people can download them and make a VCD out of them to play in their DVD players, thanks
Hi DVDnewbi,
You say "high quality clips" and then go on to say "so that people can make VCD's".
If VCD is gonna be the end result, and you're not worried about filesize (i.e. neglecting us cave-men still on dial-up in favour of you people in the 21st century with broadband) then why not go straight for MPEG1 which is the VCD standard? Anything higher would be a waste and take longer to download. All people would need to do is author it to VCD (using something like VCDEasy).
See the blue VCD link, top left of the page.
Basically, the higher the quality, the larger the filesize. I suppose you could take a high quality video and encode to Divx AVI or Xvid AVI, but then those downloading would have to do the conversion to MPEG1. More work for them and for you.
If you go the other way, you could have lower resolution (width x height) .wmv, but I'm not sure what the resultant VCD would be like... Nor how easy it is to get .wmv to MPEG1...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks, would offering downloads to turn into VCD be my only option if i wanted to offer clips people could play on their TV? what about SVCD or what about DVD quality clips or would these be way too big? tnx again
Hi DVDnewbi,
OK - Back to square one first. What's the source of these clips? Home shot footage on a DV cam? What? You see, the level of the quality of the source will be a guide as to the level of quality you go to.
As it sounds like you know, DVD is better than SVCD, which is better than VCD. The better the quality, the bigger the file size.What about SVCD or what about DVD quality clips or would these be way too big?
For example, a minute from a DV cam (original is DV AVI) encoded to DVD spec at 6,000kbps (good to high quality) gives an MPEG2 file of 43Mb. SVCD at 2,600kbps would be around 20Mb, and VCD at 1,150kbps would be around 9Mb.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Best balance of file size and quality would be an MPEG-4 codec such as DivX or Xvid.
It would require people downloading it to convert it to VCD format (or SVCD or DVD etc.) but consider this ...
You could have an option where people could BUY a VCD or SVCD or better yet a DVD from you of this stuff.
So if they like what they download that would be a good extra stream of revenue as some people might want this stuff on DVD but aren't up to the task of converting it themselves.
my PCs can't detect disc format of VCD from Thailand
By Foobar in forum Software PlayingReplies: 2Last Post: 6th Jan 2011, 11:10 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 14:23 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 01:00 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
