  1. Printed out quite a few discs earlier and am noticing that the hte text is not coming out
    out as if on a straight line. In other words, if you are looking straight on at the disc, the
    it is slanted downward to the right. I have looked at print alignment and such, but nothing seems to help this . It's as if the text is sloping downhill. Help?
  2. can you provide a scanned example?
  3. Member classfour's Avatar
    The Heartland, United States
    Are you using enhanced text? I'm thinking the settings at the far right tab where you set the shadow will produce an effect as you describe.
  4. Member classfour's Avatar
    Sorry for a re-POST:
    I just opened the program up: far right tab, DISTORTION
    DISTORT - Is it checked? If so, uncheck it and voila' problem solved.
