I'm trying to find the best TMPGEnc settings for MPEG-2 using a short AVI sample of 10 seconds. There is a lot of details in this scene and also strong movement. In certain frames I just can't get rid of block noise and some artefacts neither with 2-pass VBR nor with CBR (both set to maximum SVCD bitrates). Bitrate viewers show that even with constant bitrate encoding the bitrate isn't really constant. Does it make sense to use a longer sample for such tests? Is there any kind of buffering so that the bitrate for a scene with lots of details can have a higher effective bitrate than the specified SVCD maximum bitrate?
Thanks.
Mr. Pickert
Results 1 to 1 of 1
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 06:38 -
Check quality of burn
By amerifax in forum DVD RippingReplies: 8Last Post: 18th Mar 2009, 20:34 -
DV Quality - Check This Out
By J. Baker in forum Newbie / General discussionsReplies: 6Last Post: 16th Jan 2009, 19:13 -
found very high quality free web site to check if a file has a virus
By jimdagys in forum ComputerReplies: 13Last Post: 26th Aug 2008, 09:48 -
Burn "QUALITY" rate kbits/sec
By mikemc26m in forum Newbie / General discussionsReplies: 9Last Post: 18th Feb 2008, 22:29
