I need to mux a big (4gb) mpeg-2 file into a vob so apple's mpeg-2 quicktime plugin can handle it.
Any ideas on programs that'll mux into a large, single-file vob?
The Stop Button: Film and Literature Criticism
http://andrewwickliffe.jablog.com/ -
As long as your MPEG2 has a valid audio part, it already is vobable (okay, that was a cool word). Just change the extension to .vob. Note, however, that QT likes vob files less than it likes MPEG2 files. Do you have the QT MPG Component?
If it isn't broken, take it apart and find out why.
blog: deadsierra -
what do you mean .vob so quicktime can handle it?!?!?
if you have the mpeg2 plug in quicktime should be able to "handle" the mpeg with no probelms
what is it that you want to do with this file...............?
Muxing MPEG and M2T
By cheerful in forum Newbie / General discussionsReplies: 3Last Post: 16th Aug 2011, 23:04 -
need help muxing to vob
By ChrisDaMan in forum Video ConversionReplies: 8Last Post: 11th Mar 2011, 10:17 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 08:00 -
Converting .mpeg to .vob
By demonwarrior in forum Newbie / General discussionsReplies: 12Last Post: 17th Aug 2007, 01:33
