  1. XVID MP3 audio -> Wav -> AC3
    I'm stuck on the WAV -> AC3 (2 channel) part. I just can't get BeSweet to run at all. It seems like it runs for a brief second then stops. You can see the DOS command line. I have tried running BeSweet through both the AC3MachineGUI and the BeSweetGUI, same result. Everything is in the same folder, including ac3enc.dll. I'm getting no error message or log producing. Thanks.
    canada
    besweet took out support for ac3 encoding cause they admitted it wasnt very good so you will have to look for an older version or you can try ffmpeggui to make your ac3 which i use all the time.
  3. Works like a champ. Thanks!
