Why does it take over 24hrs to convert a DivX .avi to .mpg format using TMPGEnc? Is there any way to speed this process up?
Results 1 to 15 of 15
give us more information:
whats your system - how fast
what settings did you use in TMPGEnc
it can take over 24hours if you select a lot of filters or select the "best" motion search setting -
Ok, here are the options I have selected:
Under Canopus DV Codec
-> Enable reading referrd format AVI thorough network
Under Panasonic and I-O DATA DV GigaAVI Codec
Under CPU Setting
-> Enable MMX
Under VFAPI Plug-in
Direct Show... Priority 1
AVI2(OpenDML)... Priority 0
BMP/PPM... Priority 0
Wave File Reader... Priority 0
DVD2AVI Project... Priority 0
TMPGEnc Project... Priority -1
AVI VFW... Priority -2
Is there anything else you need to know? -
your computer is how fast?
you have how much ram?
you set the "motion search" to ?
did you select any filters?
what template did you use?
what is your source?
what is your desired output? -
My computer is a Pentium II with 30 Gigs of Ram. I have a conversion in progress (17 hours to go and counting) but I don't see where to find the info you're looking for. I gave you all the options I had checked from the Environmental Settings area. I have the program set to "High Priority - When active" It's set to 320x240 resolution.
I'm sorry, this program is still new to me so I'm not sure where to find all the info you're looking for. -
I think I can safely say that 24 hours is fine - your comptuer is on the slow side and has too little RAM
sorry thats probably why it takes so long -
30 gigs ? I assumed that was some sort of type-o
I dont think 30 gigs is possible - I've seen 4 gig on servers
Obviously he doesnt really know what he is talkin about...I mean u ask what speed an he say pentium II....Thats great but whats the clock speed(Mhz)...The 30Gigs just go figure its the hard drive...I seen all the way to 60hrs just depends on the settings and it depends on what ur encodeing...Divx usually takes long...I have a Pentium III 800Mhz and 384MB of ram and it usally takes around 6-10hrs but seen well over 24hrs but depends on the file...l8r
Sorry, I misunderstood your question, don't have to get all critical on me
128 MHz is what my computer is running at. 30 gigs was the Hard Drive size. My confusion. Thanks [Cursed] for answering my questionAll I wanted to know is whether such long conversion times are normal.
Sorry Stinky, you made it harder then it needed to be
Later. -
OK, I doubt you have a 128Mhz cpu (not saying you don't, it's just I can't reacal anyone making a cpu at this speed). Let's just leave it at your PC is really slow, and that's why TMPGenc takes so long.
I had a K62-500 and it took me 18hrs to convert a 90min DivX file to MPEG1 (xVCD). To convert the same file on my Tbird 1.2Ghz takes ~50min. -
24h, if you have s slow PC its good enaugh and you must be pacient, but...
To know all about you machine do this: -
Start>programs>accessories>systems tools>programs information.
Type each word and when the > apears click enter and so and so...
Read all and be pacient.
Spend more time studing your computer and be happy... -
128Mhz cpu - P2 NO SUCH ANIMAL !
P2 was 233Mhz to 450 .... ish
To give you an idea of encode times .It took me 8 hours the other day to do a 98 minute movie.
Machine is 600Mhz O/C to 903Mhz , 384Mb RAM.
24houres is reasonable
MP4 video from Handbrake takes forever to convert or burn to DVD
By Video Student in forum MacReplies: 1Last Post: 2nd Jan 2011, 23:22 -
MP4 video from Handbrake takes forever to convert to MPEG2
By Video Student in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jan 2011, 18:44 -
Ripbot takes forever to "Please Wait... Initializing..."
By nikemouse in forum Blu-ray RippingReplies: 13Last Post: 21st Mar 2010, 15:12 -
Extracting Frames From Video Takes Forever
By FOBOS in forum ffmpegX general discussionReplies: 0Last Post: 14th Apr 2009, 11:20 -
Why does it last forever?
By NormaJ in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 10:28
