Hi,
I have a XVCD Template , it has the options for me to encode with functions like DVD ( CQ, VBR, CBR ) and bitrate to whatever I wish. The default audio is 44.1Khz, I modified it to encode audio to 48Khz. Does it mean I have now is a mpg2 file ( dvd file instead of xvcd )? even though it is xvcd template ( 352x240 resolution, the same as low dvd resolution which is also 352x240 )
No, you made the MPEG1 compliant with DVD. That's what you intended, is it not? (Assuming I understand you correctly.) Have you saved the modified template under a new name?
Pull! Bang! Darn! -
It kind of hard to explain, I try to explain again, hopefully you guys can understand better and help me solve it.
I got a xvcd template from someone else, in there, I can change the video and audio bitrate, choosing options such as CBR, VBR, CQ ....
Then I edit this template in notepad ( save under new name ), in this modification, I modified its default audio ( 44.1khxz ) to 48khz ( which is DVD audio ), so from now on, instead of encode the movie into xvcd 44.1khz, it will do xvcd of 48khz. Does that mean I got a mpg2 files instead of mpg1 ???
Note: the resolution of xvcd is 352x240 , the same as low dvd resolution
I hope this clear up a bit
thanks -
Originally Posted by BV2001
Asked and answered, you have an mpeg1 that is DVD compliant.Originally Posted by fritzi93"Art is making something out of nothing and selling it." - Frank Zappa -
one more quick concern ?
mpg1 with DVD Compliant encode 2000kps 352x240 160kps 48Khz compare to the same specs but encode with low res dvd template ?
Any thing difference ?? quality wise ? compatibilty wise ??
WMV Modification Without Reencode
By frmys in forum Video ConversionReplies: 4Last Post: 1st Sep 2011, 06:24 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 11:52 -
Any chance for a spell check modification or code snippet?
By G)-(OST in forum FeedbackReplies: 22Last Post: 7th Jun 2009, 01:41 -
Flash -> H.264 Conversion Application or Modification Wanted
By dexgarvey in forum Video Streaming DownloadingReplies: 2Last Post: 10th Dec 2008, 17:48 -
Anybody have any experience w/ Child Support / Modification???
By makntraks in forum Off topicReplies: 18Last Post: 27th Feb 2008, 12:44
