I have a Sony TRV320 and when I'm transfering the video to my computer I notice the contrast is real low. When I view the footage through the viewfinder the video is so much more colorful and brighter. I have used a few capturing programs and get the same thing with all of them. Also after I make the DVD and view it on my tv it comes out the same way low contrast so Is this a norm with these Cameras or is it something I can do to make it beter? Thank's for any help you all can give.
The only thing i can advice to you, set hardware in "auto" or default mode,
check this also for your software, set all in default settings,
or install software again, also check cables, for good connections..Thanks,
Yodel -
Unfortuantely, DV cameras are famous for their high resolutions, but notorious for their low contrast in low lighting. You can also use your editing software to adjust your video contrast once your DV transfers to your system.
Hello.
Captured video is in black and white (NTSC vs PAL problem?)
By Helena in forum Capturing and VCRReplies: 27Last Post: 18th Apr 2023, 18:34 -
What would you do with this captured video? (Comb-like problem)
By Asterra in forum Capturing and VCRReplies: 7Last Post: 6th Sep 2011, 11:13 -
Problem playing webcam captured video.
By srisan_msc in forum Capturing and VCRReplies: 2Last Post: 9th Jun 2010, 21:19 -
Problem with audio gradually going out of sync in ts file (captured video)
By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2010, 11:12 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 06:06
