I would like to replace 6 PGCīs in a VTS, is it possible? The reason is, I tried to reencod an episode disc with both "the big 3" and "DvdRebuilder", and everything went fine, except both programs reencodes the animated menues which makes them not to work anymore. I donīt know if it works, but I would like to try to copy the 6 menu PGCīs from the original files to the encoded files and replace them. Is it possible? Will the menues work and point to the correct positions? The dvd layout is pretty simple, it is 1 VTS (VTS01) which contains 20 PGCīs (PGC01-PGC20). The menues are PGC01 to PGC06, and the rest are 1 episode per PGC. As I said, the menues are in the reencoded files but doesnīt work since I can not press a menubutton since they are not highlighted. The menu is like a one minute long movie instead... Suggestions, please?
Results 1 to 1 of 1
Print DVD Information (VTS - PGC)
By dw-wizard in forum DVD RippingReplies: 0Last Post: 27th Sep 2010, 14:54 -
rip DVD content by VTS, instead of PGC?
By lordsmurf in forum DVD RippingReplies: 7Last Post: 28th May 2009, 10:35 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 11:28 -
Can you replace a VTS on already authored DVD?
By kpic in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2007, 07:36 -
framserve PGC
By kurbads in forum Newbie / General discussionsReplies: 10Last Post: 3rd Jul 2007, 08:03
