Hi,
I have a couple of movies in the above mentioned codec, i have tried to decode it with the latest codecs downloaded from microsofts site.
When i open the file in Tmpgenc, it just closes the program, even if i try to frameserve from Virtualdub...!
But i have managed to encode it with virtualdub in to a lossless codec, wich i can open in tmpgenc, and encode to mpeg2, wich is my goal.
The picture quality is ok... (okay the codec sucks!)
But my problem is that the resulting mpeg2 "jumps" ei. i guess it plays 15-20 frames smooth, and then it looks like it skips som frames.
It almost look like it was encoding from 23.976 to 25 fps. But this is not the case, everything is 25 fps.
I was just wandering if anyone have tried this codec, and maybe had some experiences?
Thanks in advance.
Chr
Results 1 to 1 of 1
Where is the Deadly Viper Assasination Squad, when you need it ?
Building a new PC - This is annoying
By Des in forum ComputerReplies: 5Last Post: 9th Jul 2010, 17:54 -
ZoneAlarm very annoying problems
By Tbag in forum ComputerReplies: 32Last Post: 26th Feb 2008, 22:02 -
Isn't this annoying?
By Midzuki in forum FeedbackReplies: 17Last Post: 4th Feb 2008, 13:34 -
The Most annoying Celebrity
By Cirone in forum Off topicReplies: 22Last Post: 4th Feb 2008, 13:32 -
Annoying error i keep getting...
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 04:33
